View Full Version : HELP! C253 Error Code C-3821
ckegher
07-16-2009, 10:57 PM
I went to print out something, as usual, like everyday, and C-3821 error code shows up. PLEASE HELP!!
ckegher
07-16-2009, 10:58 PM
ASAP
If opening and closing the front door does not reset the machine turn off machine, switch back on while holding the utillity/counter key, after you see a black dot in the corner of the lcd let go of the utillity/counter key. the machine will take a while to boot up, and when it does you will see trouble reset on the lcd, press the reset on the lcd, switch off the machine leave it off for 10 to 20 sec's and then switch back on. If this does not work you have a screwed fsr, if it does work, it might come back at some point if the firmware is not up to date , the latest is vR6
Good luck
ckegher
07-16-2009, 11:49 PM
It works just fine now....Thank you so much!!!!!!:D:D:D:D
danielross
05-03-2010, 01:54 PM
are you talking about the kodak esp 5 printer? im having the same problem, where is the utility button?
