View Full Version : Ecm konica 7045
pudgi300
07-17-2009, 02:17 AM
Have a Konica 7045 that boss got at auction. I can't get in service because of the ECM password. I have a printout that was with the machine that says the key op is 00000000 and other is 0000. I can hold down the p button all day and not get to screen for service password. Someone must have changed the password after the printout was made. Is there a powerup way to get in service mode so i can reset and get rid of the ecm . I never worked on 7045's just bizhub 1050 and c6500 ,canon Xerox. I also downloaded the manual about the ECM and if you have no password you are out of luck.
Thanks Warren:)
nmfaxman
07-17-2009, 03:36 AM
Try 25 mode to get the ECM passwords.
jeroen2005
07-17-2009, 02:00 PM
Go to the 36 mode-list output- there you can see the codes.
Hold help button en switch machine on.Enter 1234 then switch ecm off.
pudgi300
07-17-2009, 03:02 PM
I can't get past the ecm screen asking me for a 5 digit password. Tried hitting the help button and can not even get to the key op mode. If i can get in service mode a can shut this thing off.
I have all the service guides,service manual and the doc for the ecm.
pudgi300
07-17-2009, 03:06 PM
will try the help button thing again. Had to read it again sorry, Will report back
OK went back and held help button and power on enter 1234. . Went to ecm and turned it off. Why didn't i think of that??? Was that in the manual or something that is special info?? Thanks for the help and quick response.
:):) Later Warren :)
jeroen2005
07-17-2009, 09:00 PM
It is a kind of standaard 0000 or 1234 master key code 00000000 or 12345678
cdleon
02-28-2011, 09:34 PM
i was working with Konica machines and remember that is in mode 25, you can change the password. Meke me know maybe i can help you, i have a service manual of konica 7020, y the same modes.
