View Full Version : kyocera fs-1900
wulffservice
07-23-2009, 06:14 PM
Have a code F020 have no idea what it is can any one help. Thanks
Craigdumass
07-23-2009, 06:42 PM
Try switching your drivers to KDPL and update your firmware
TheOwl
07-23-2009, 11:59 PM
Accordong to the Service Manual, F020 is one of the following.
1. Defective main memory (RAM) on the main board.
2. Defective main board.
3. Defective expanding memory (DIMM) on the main board.
The error means:
Checksum failed with main memory (RAM) on the main board or expanded memory (DIMM)
Most of the time, I have been able to fix the by leaving the printer turned on at the error and then removing the power cord straight from the machine. Then I plug it back in again. Sounds crude hey? But I have never had to replace a main board in one of those machines yet.
You can also try a firmware upgrade and see if that helps.
