View Full Version : Using Danyl with Bizhub 350.
EbolaSandwich
07-28-2009, 03:13 PM
We recently got 2 used Bizhub 350s, and I'm trying to figure out how to utilize our Danyl-8PE key counters with the copiers.
We did find the interface cable on the right side and hooked a Danyl to it, but we need to know how to interface the Danyl with the copier so that, in order to make copies, you have to enter a user code in the Danyl.
Any info would be great. :o
Thanks in advance!
TheOwl
07-29-2009, 12:01 AM
You need to go into service mode and from there enter into security mode. You can then set the keycounter from one of the menus in there which will disable the copier until your external counter fires up the enable pair of wires going to the copier.
EbolaSandwich
07-29-2009, 03:22 PM
I was not able to find "Security Mode" or any menu which disabled the machine, and I could not find anywhere to utilize an external key counter.
Is "Service Mode" and "Tech Rep Mode" the same thing?? [yes, I'm new to this machine :eek: ]
Here's the menu I get when I enter Tech Rep Mode:
http://img.photobucket.com/albums/v671/SomeLAmeNoobGuy/TechMode1.jpg
Juggy
07-29-2009, 07:31 PM
press stop 9 at this menu you will get into the mode
EbolaSandwich
07-30-2009, 03:20 PM
That's it! :D
Thanks to both of you.
pfarrell4
10-15-2009, 12:57 PM
Does anyone know the pin outs for the key counter interface? We're trying to hook one of our card readers up to it, and need to know which pin corresponds to what. I've used the control device on Toshiba, Canon & HP copiers with no issues, but I've never worked with a Konica Minolta before. Thanks for any assistance you can provide!!
The cable that was provided by the technician is below. The black end goes to the copier and the larger piece is supposed to match up to our copy control device. There are four pins that should correspond to these (according to the documentation of our card swipe):
Copier Enable (NO)
Copy Pulse (+)
Copy Pulse (-)
Copier Enable Relay Common
http://img390.imageshack.us/img390/2950/keycounter.th.jpg (http://img390.imageshack.us/i/keycounter.jpg/)
TheOwl
10-15-2009, 10:28 PM
I haven't got the schematics but the pin out goes something like this.
Pins 1 and 2 - Enable
Pins 3 and 4 - Count
