View Full Version : Bizhub Pro C6500 / C6501 / 65hc.
jma676
07-30-2009, 04:06 PM
Hello i`m looking for Firmaware version Historial to the Bizhub C6500 / C6501 / 65hc.
and i nedd doc for GCA-30 / G00-40. other, i need G00-30 / GMG-40 / G00-50 / G00-60 Firmaware and doc.
Si@danwood
07-30-2009, 07:12 PM
Why do you need the different versions? As long as the Fiery is on latest version ver 50 zip should do fine!Get in from your normal KM website as usual there should also be a revision history there as well...Si
jma676
07-30-2009, 10:25 PM
Ok i need revision this versions for view all error solution.
I start my Bizhub Pro C6500 (IC-408) With G00-30 Firmaware version and Version Up with G00-40 / G00-41. And never can find solution Definitive of problem C22xx, C4850 and other image Problem, anyway i resolve this problem with adjust my bizhub but i want solution this problem.
I understand that these versions are solved or at least reviewed several of these problems.
