Minolta di 250
  • vaclav borc
    • Jan 2008
    • 75
    Minolta di 250
    How can I adjust fusing temperature.I need to make it upprer.Toner is not fused completely.Stays on fuser roller.
    Fuser roller is replaced.
  • tonerspot
    • Nov 2008
    • 79
    you can not adjust the fuser temperature,but your problem is not in temperature,send more details
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      If you have changed the UFR, and the toner does not stick, I bet the problem is with the screws that adjust the pressure between rollers. Make sure the bushing around the long screw goes in the hole correctly.
      • Claudio
        • Feb 2007
        • 235
        Other possibilities :
        -Generic heat roller,
        -generic toner,
        -heat roller bushings (if it has them),
        -Humid paper (try copying on the 2nd side of the paper to see if it improves),
        -Also make sure the press roller is good and that the bearings are not freezing up grinding away at the press roller shaft causing uneven pressure.
        • Hansoon
          • Sep 2007
          • 3350
          Fixthecopier is right, that could be very likely the cause. Happened to our techs several times.
          Hans
          “ Sent from my Intel 80286 using MS-DOS 2.0
          https://www.copytechnet.com/images/smilies/biggrin.png
