View Full Version : HP Laserjet 2605dn color misalignment
SOCPWB
08-06-2009, 10:26 PM
I am trying to fix a HP CLJ2605 that is printing all 3 colors about 2 or 3 mm below where they are supposed to be. I have swapped the cartridges, used the Clean ETB function under Service menu, re-caliberated it several times, and updated the firmware, none of which seemed to make any improvement. Does anyone have any suggestion on what else I could try? Thanks in advance.
Gleq
09-07-2009, 10:41 AM
Hi
Check the gears if all is right
change the ETB
good luck
bernyb
12-10-2009, 08:05 AM
For the answer to this problem go to fixyourownprinter.com You need to do a reset of the nvram but I forgot how to do it off hand.
