View Full Version : c500 can't identified Creo IC-301
kmcopytech
08-09-2009, 06:00 AM
Creo IC-301 is connected C500 host,
Turning On the IC-301 Print Controller and C500.
Press "print button" can't display printer screen...??
Any help...
Thanks!
My E-mail: kmcopytech@gmail.com
random
08-10-2009, 08:09 AM
If your talking about the print button on the copier, then no you won't see anything. This controller is supposed to have a screen, keyboard and mouse. If you press the scan button you should see 3 scan destinations.
kmcopytech
08-12-2009, 12:40 PM
1\C500 host can't display the status of print controller???
2\Print Creo IC-301 test page after,C500 host didn't respond.
3\Press "print button" can't display printer screen...??
Any advices and helps!!!
Thnks!
Jack
buster68
08-12-2009, 02:22 PM
Make sure that the C500 has firmware version 14-CNU0.
You may have to reboot the copier and the Creo several times before they connect. Touching the printer button on the copier will not show you anything, the creo is a completely different from the fiery.
Specilist KVN
08-14-2009, 06:19 PM
Yes, and make sure the C500 is FULLY booted up before you boot up the Creo.
Also check the cable, the connecting on that model is not the most "reliable".
