View Full Version : Konica 2125
LandE1
08-11-2009, 05:01 PM
have a code of f45. Machine will turn on but nothing else. Any suggestions we can do ourselves?
JustManuals
08-11-2009, 05:11 PM
Yes, open the phone book and look for a Konica copier dealer, call them up make an appointment, mix up a pitcher of margaritas, start sloshing them down and wait for the technician to arrive. When the tech gets there, explain the problem and go back to those margaritas.
HtH
Paul@justmanuals.com
Col. Buckshot
08-22-2009, 09:25 PM
If your code is a F45-1 thats a lens motor code. Watch the lens carriage when you turn on the copier - it should move right and left to set home position. The motor that drives the lens carriage has a small white gear. That gear spilts, you can fix it with thin super glue. You have to remove the control panel to get to the motor. Let me know if you need more detailed instructions.
donaldtex
08-22-2009, 09:45 PM
What is lens?:confused:
Yes, sir. I strongly suggest you to call a pro, these machines were a real headache-maker, don't forget the carriage cables getting tangled, that also causes these codes...:mad:
