View Full Version : service / tech rep mode not accessible
clubsys1
08-12-2009, 04:21 PM
recently replaced the drum and developer and cannot access service mode for bizhub 350. The machine instantly defaults to code c2557 and will not on re-boot open to service mode.
any suggestions?
deep
08-12-2009, 05:41 PM
You should carry out F8 right away after machine being turn on.
AZ Copier
08-12-2009, 05:52 PM
Have you tied getting to service mode through trouble reset?
clubsys1
08-12-2009, 06:29 PM
i have tried holding utility button down and power on and still no reset option...just error code.
How can i or why can't i get directly to F8 before error?
Juggy
08-12-2009, 07:20 PM
hi do warm boot when you get the konica minolta logo with a dot in centre left side press 3 then enter "00000000" enter reset mode. when you are in this mode enter stop,0,0,stop,0,1. then you can run F8 then rest the counters for drum & Developer counter. good luck.
clubsys1
08-12-2009, 07:29 PM
I tried to do this earlier...when i boot the machine and get to the konica logo and press 3, nothing happens. i just end up at the same error code.
what am i missing?
3angle
08-12-2009, 08:21 PM
To get the "trouble reset" on BH250/350, You have to press the
"warm restart switch" which is under the CompactFlash cover (about 10cm to the left from the LAN-female RJ-45) and than when a black point appears at the center on the left-hand side of the screen, enter “3” from the Key Pad,
and enter the 8-digit service code and touch "END"
Kmdurrin
08-12-2009, 09:27 PM
You may want to try a new drum and developer.
Per SSD bulletin #TAUS0655275EN
SOLUTION: Replace both the drum unit and developer at the same time. Once the code occurs, developer must be replaced to properly recover.
The correct procedure for replacing the drum is as follows:
1. Select Tech. Rep. Mode => Counter => Special Parts Counter => PC Life.
2. Press the Clear Key to clear the counter value.
3. Turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU.
6. Remove four screws (silver) and disassemble the Photo Conductor Unit and the Developing Unit.
7. Replace the Photo Conductor Unit.
8. Remove three screws and the Developer Scattering Prevention Plate.
9. Remove the Toner Supply Port.
10. Remove the Developer.
11. Set the developer while rotating the gear in the direction of the arrow.
12. Reinstall the Toner Supply Port.
13. Using three screws, secure the Developer Scattering Prevention Plate.
14. Install the four screws to secure the Photo Conductor Unit and Developing Unit.
15. Install the IU in the copier.
16. Turn ON the main power switch.
17. Select Tech. Rep. Mode => Function => F8 and press the Start Key.
Notes :
a. After replacing the developer, be sure to execute F8 under Function of Tech. Rep. Mode.
b. When the main power switch is turned ON, execute F8 quickly.
clubsys1
08-12-2009, 10:12 PM
tried the reset...didn't work.
Why can i not access tech rep mode from the menu? better yet, how do i simply get to tech rep mode to reset the counters because i'm not doing this right.
thanks
pepper38_cnd
08-12-2009, 10:53 PM
Turn the machine on with the right side door open, enter tech rep mode and go to F8, close door when the start indicator changes color press to start the F8.
pepper38_cnd
08-12-2009, 10:57 PM
Oops I didn't see that you had not reset the counters. Do as above mentioned turn machine on with side door open, access tech rep mode and reset counters. Turn machine off then on still with side door open access tech rep mode and go to F8 close side door and when the start indicator changes color press to start F8, when F8 completes recycle power.
Hansoon
08-13-2009, 04:55 AM
5. Remove the IU.
Notes :
The bulletin left out to cover both collars (Drum Spacers) during the starter exchange procedure. This to avoid starter spilling onto it. Starter messing the collars seems to be the the main cause of ripping the rear mag roller seal causing early drum damage.
Hans
clubsys1
08-13-2009, 02:19 PM
tried this yesterday, per the service manual. when i turn the machine on with the right door open, it boots to the close door indicated by arrow screen...no options are ever presented and keys do not respond. if i close the doors, it goes right to the error.
i tried a new drum and developer this morning, but same result. still cannot access tech rep mode.
pepper38_cnd
08-13-2009, 05:00 PM
The side door does not prevent you from entering tech rep mode. You must have another problem possibly a stuck button.
pepper38_cnd
08-13-2009, 05:06 PM
The trouble reset is not done by holding the Utility key. On these machines it is done by pressing the button next to the flash card slot.
clubsys1
08-13-2009, 05:23 PM
yes, i am using the little black button next to the card slot...when the machine boots, i can put in the 00000000 code and get to the screen with trouble reset. however, pressing trouble reset yields nothing. the button is non-responsive.
What's weird...yesterday it wasn't even beeping, and today it is beeping on click, but still no action/response.
Juggy
08-14-2009, 06:45 AM
hi, when you get to the screen after entering 00000000. Dont press trouble reset instead enter stop,0,0,stop,0,1 and you will go into tech rep screen. Reset the special parts counter for developer and drum to zero by highlighting and press c then you can switch off and switch on the main switch and the machine should be working fine
clubsys1
08-14-2009, 04:39 PM
i have tried that and all i get is double beeps when i push any button on the keypad...the trouble reset button doesn't work and the keypad is basically locked out from this menu screen.
...something else is up, but i can't figure out what.
