View Full Version : konica minolta di 2510 abort code
javier4065
08-14-2009, 05:11 AM
Hello friends this copier when I make copies and there is not pa in the tray, the display says abort with any numbers and simbols,what does it mean? and How can I solve it? thanks.It happened just when there are not papers in any tray.
what numbers and simbols ? you can try rewrite the firmware and see :p
javier4065
08-14-2009, 05:43 PM
thanks for your answer,display says first line code 0x001 01 001 second line TSK NATLE= TRT04007 THIRD LINE TSK ID=0X00000FA7 FOURTH LINE SP=0X81C91E20 FIFTH LINE RA=0X80618DE8 6TH LINE BUILD_1267A.030826 and sometimes
code 0x00100101001
TSK NATLE=TRT04011
TSK ID= 0X00000fab
sp = 0x81c91e10
RA = 0X80618DE8
build_1267a.030826
what does mean these? and what is the action to download the firmware? thanks.
backspace
08-14-2009, 05:48 PM
Just rewrite the firmware.
javier4065
08-14-2009, 11:09 PM
Thanks How do I rewrite the firmware?I really don't know how to do it? but Im a technician and only I need explanation abou it? thanks
Did you have the firmware ? this model very easy , just clean the flash card and copy the new firmware direct to the flash card. :)
