View Full Version : Firmware Imaging Toolkit
xpress
08-18-2009, 10:14 PM
Cannot find. I know I can get it from Onyx as a tech, but trust me, I log in and its not under my search menu as a sales person, all the other software, ftp, anything is there.
Any links or PM?
aidil rashidi
08-19-2009, 08:17 AM
Konica Minolta Australia (http://solutions.konicaminolta.com.au/cses/login.cfm)
but i think you need to register to login
mrwho
08-19-2009, 09:14 AM
I personally never liked the toolkit - unless it has gotten much better since the last time I used it.
I very much prefer mini-cygwin, it is (or used to be) much faster and error-free - why don't you use that instead?
Bizwork
08-19-2009, 10:41 AM
Hi
If you go to this link you can have a copy of the Toolkit.
RapidShare: 1-CLICK Web hosting - Easy Filehosting (http://rapidshare.com/files/269056220/FirmwareImagingToolkit2006Ver2.5.4EN.zip.html)
xpress
08-19-2009, 05:58 PM
I downloaded cygwin and got it all, but when i go to write the firmware to a drive letter i type in like C:, Non removable, good,
So i type E: (for my CF card) and I get a bunch of crap unreadable txt, not sure if it is a bad install or a bad command but whatever.
mrwho
08-19-2009, 06:23 PM
You're using Mini-Cygwin or the standard Cygwin? The standard one will not work, AFAIK. You need the mini-cygwin version.
Mr Spock
08-20-2009, 02:53 AM
Which version did you use? I have the latest and it works fine. As to where to find it, it should be located with the firmware downloads. Most sales people do not have access but some do.
aidil rashidi
08-20-2009, 07:19 AM
i use ver 2.5.5 and it works fine. it only give problem if you use a high speed CF (e.g 80x and above) for fw upgrade.below are the supported models:
bizhub C250/C252/C300/C350/C351/C352/C450
bizhub C250P/C352P/C450P
bizhub 200/250/350
Di1810/1810f/2010f/2510/3010/3510/2510f/3010f/3510f
bizhub C650/C550/C451
bizhub C353/C353P/C253/C203
xpress
08-21-2009, 11:43 PM
Damn, lexar 512 not working :( have to be a 256mb sandisk?
mrwho
08-21-2009, 11:51 PM
I only had success with cards from ExtreMemory (or however you write it), 128Mb and 256Mb. Tried it with a Kingston 256Mb without success.
Trouble is, it's hard to find compact flash cards nowadays, and even when you do, rarely they are bellow 2Gb.
copytechman
08-21-2009, 11:58 PM
True nuff! I have 2 cards (256 and 128mb) and only the 128mb card works on everything! (Its a verbatim cf card!)
Regards!
A!
mrwho
08-22-2009, 12:10 AM
I had an idea: what about a list of known working and non-working CF cards? I started a new thread here (http://www.copytechnet.com/forums/konica-minolta/24187-compatible-cf-cards-list-techies.html#post92428). Send your feedback and I'll update it. I'm sure it will come in handy.
