View Full Version : Hard disk upgrade for Bizhub C350
Methmann
08-19-2009, 02:13 PM
Hi mates :)
I have a broken "hd-501" hard disk extension for a bizhub c350. A new disk is very expensive although its looking like a normal 2,5" hdd. But my coworker says that i cant just put in a normal 2,5" hdd drive, there must be some special software or anything on the original hdd drives??
Do any of you know any way to use a normal hdd drive from a notebook etc. ??
Thanks in advance :)
Regards
Methmann
emujo
08-19-2009, 02:58 PM
A standard SATA driive works for the Bizhub 751 series, no special software needed, just HDD format. I would try before I purchased from KM, can't make it any worse!!!
buster68
08-19-2009, 06:31 PM
you can use a standard 40-80gb notebook harddrive. Just do the physical format first after you install it on the copier. Then the logical format.
We use them all the time, lot less expensive than buy from KM.
jrf
08-20-2009, 07:17 AM
Ya we also use standard labtop HDs and they work fine
apache_cat
08-20-2009, 12:46 PM
Agree with Buster.
Just be aware that the physical format can take over 1/2 hour. The logical format only takes a minute or two.
ni311
08-20-2009, 04:29 PM
FYI, KM does not make the hdd's that are fitted on the MFP's. But Toshiba does...
Methmann
08-24-2009, 08:15 AM
Okaaay, nice :)
But my coworker says i cant just take a standard drive... maybe heīs wrong.
Itīs worth a try :)
Thanks in advance ;)
Methmann
08-24-2009, 10:23 AM
Now i have installed a 60 GB samsung hdd. I have tried to make a physical format, but in the end of the formatting, it makes an error "C-12C8" ??
Methmann
08-25-2009, 01:59 PM
It was not a Samsung but a Seagate, sorry :/
Now i have tried with a 20GB Toshiba hdd, and it worked fine. So after that i have tried with another Seagate 60GB hdd like the one on first try. But it makes the same error "C-12C8"... Maybe its something with the brand? or is 60GB too much for the Bizhub C350 to handle??
JSC
08-25-2009, 02:05 PM
I fitted a 160Gb one last week, got it straight of the shelf from PC world :)
Methmann
08-27-2009, 11:00 AM
Okaay.. Which Brand is the HDD???
