View Full Version : error codes
kwieringo
08-20-2009, 04:28 PM
konica minolta bizhub 420 error code T82 after a fax has been attempted.
Thanks in advance
Ken
ni311
08-20-2009, 09:23 PM
Are you sure it is an error code? From what I know, the error codes for fax are formated like this C-Bxxx
kwieringo
08-21-2009, 01:19 PM
Don't know, it was reported via email by a user and the machine is in another building.
I went to look and the code was gone from the display, so I suspect since it was a new user, they were the error.
Thanks,
Ken
mo0651
08-21-2009, 03:00 PM
T82 is a no answer code reported by the fax. Problem with other fax no answer, not dialed correctly. Need to dial a 7 or 9 or other access code before phone number. That kind of thing.:cool:
xpress
09-25-2009, 06:48 PM
Im getting this 2 on a c250, The fax board works on ourmachine, but when In the it nec25c2 or whatever, it just sits after making a fax, and says waiting in the job log screen, coding out to a
t-82 (T82 Call control Answer tone (CED/DIS) waitingtimeout after dialing at calling)
IT was in this machine for years, going to check phone line today but wierd stuff
chexin51
11-09-2009, 06:25 PM
Although this was on a C203 the fax systems are probable similar
Problem: at a new installation
Fax error T82 when sending a fax long distance with a Pause and then user code
example: 914507561748P607
on Activity Report - Result = No Answer
Solution: Dialing Method was "20 pps"
it should have been "PB"
Utility - Admin.Settings - Fax Settings - Line Parameter Settings - Dialing Method = PB
