3510 Unknown code C143F
  • xpress
    • Jun 2008
    • 63
    Started up 3510 this morning, instantly coded, will not start if reseted, get to "ready to copy" but imiditly codes
    Not Listed in service, tried to use a few other related guides but the c143 (no f) was listed as mobo damage, and other things so Id like not to believe that
  • xpress
    • Jun 2008
    • 63
    Fixed with Firmware update :-/
    • The copier guru
      3510 unknown code
      AFR-19, C143F (C-143F) error code which is not found in the Service Manual.
      [Solution]
      CAUSE: The code, C143F, refers to an AFR adjustment which is not possible to perform in the field. Typically, it is an indication of an open interlock on the AFR-19, which may have opened before finishing the document feed.
      SOLUTION: Secure all document feeder covers.
