View Full Version : Fusing Issue - Konica Minolta DiALTA DI2510F - Help??
REMCO
08-27-2009, 02:03 PM
I have a customer with a DiAlta DI2510F the copies are coming out with raised print and the image will rub off. I have raise the fuser temp. & exchanged fuser unit with a known good unit. Not sure what else to check.
Also I'm getting a message to "change imaging unit"; I have installed new OEM drum, OEM DV and OEM toner - reset maintenance codes; message remains.
Any suggestions????
My hair is turning gray(er), please help.
Remco Tech :confused:
vijaysharma
08-27-2009, 05:29 PM
Hi,
Little clear the fusing problem what happen when you replaced the fuser unit.
the massege replace imaging unit that means you have to replaced complete imaging unit with developing unit.
mitchl
08-27-2009, 05:56 PM
2 things, did you reset PC Life counter and did you run F-8 after PMing the machine?
REMCO
08-28-2009, 02:32 PM
vijay thanks for replying
To answer your question,fuser exchange seemed to make no differance.
On the other one I changed only the developer & run the F-8 Simm not the
developer unit
thanks Remco Tech
REMCO
08-28-2009, 02:35 PM
Thanks Mitchl for answering
Yes I did reset PC life counter & run the F-8 Simm.
Thanks Remco Tech
alonzo
09-18-2009, 08:18 PM
Thanks Remco Tech
you need to replace fuse in IU Unit pico fuse.08
mitchl
09-18-2009, 08:40 PM
Does it say to replace or Install imaging unit! To be honest I dont remember ever seeing replace IU but then again I stay sheltered in the office, Just asked one of my techs and he is scratching his head also....... Maybe in the initial FW version it was used or something along those lines.......... Yo KM guru's feel free to chime in!
R U sure this isnt what it says? If so try this I have had this happen a few times.
Subject:
PLEASE CHANGE PC DRUM message will not clear.
Description:
Solution:
To clear the PC Life counter, perform the following:
1. Enter Tech Rep mode by pressing Utility, Meter Count, Stop, 0, 0, Stop, 0, 1.
2. Select Counter.
3. Select PM.
4. Select PC Life.
5. Press Clear key to clear the count value.
6. Power OFF the machine and remove the power cord from the outlet for approximately one minute.
7. Reconnect power cord and turn power ON.
the important part is to unplug the beast after resetting the PC life counter
This model no have fico fuse . only Di251 351 got it
