View Full Version : Sharp SF-7900
jerilee001
01-25-2007, 11:44 PM
Code H4 is coming up on copier....can anyone help? Any info. would be appreciated..
thanks,
jerilee
Wild Bill
01-26-2007, 01:58 AM
H$ error cod is a fuser error. This is probably a thermal fuse. You then have to reset it with cioi 14. It also could be a lamp and or a thermistor.
bilyahn
01-29-2007, 11:08 PM
H4 is generally a fuser problem. Either the fuser did not heat up in time. If you hold down the copy button it will give you a 2 digit sub code (01, 02, etc). Check your lamp to see if they are coming on.
Good luck. Bil
Lawton
01-30-2008, 05:02 PM
Check to see if lamp comes on, if not could be lamp.
Wild Bill
01-30-2008, 08:16 PM
A little redundant don't you think?:confused:
