View Full Version : di 5510 paper feed problem
brent
09-01-2009, 08:45 PM
machine has 1.4 million. all maintenance has been performed. question on tray 1 will feed only one at a time without jamming. multiple will jam also tray one is the top left letter tray. I replaced the feed and take up tires. both feed and take up clutches. and the drive shaft. that drives the take up.. if I take out this assy it will work in another tray. but nothing will work in it's place. replaced everything. then I swapped out the whole tray with a working tray. works great. there is something in tray one that if making it jam. basically it will pick up the paper (1st sheet) and take it in the horizontal. next sheet will get stuck in the pinch of the take up roller. then it jams. what else would you gentlemen recommemd for fixing this paper feed problem
brent
