View Full Version : C451 printing quality
gamalmehdar
09-02-2009, 09:58 PM
this copier its work ok? but the printing on thick color paper in monocrome is not correct comparism with xerox . the plack is not printing good
any adea for this
thanks for all:confused:
don't compar with xerox .Beacuse fusing section design problem .did you have change the plate (modification ) ?
minimerlin
09-03-2009, 09:31 PM
any adea for this
Use the engineer adjustments to increase transfer for thick stock
rtapia
09-13-2009, 02:07 PM
Make sure the customer is selecting the correct media in the driver and it matches the copier settings, especially when using the second side.
If there is a color one side and b/w other side have customer run the color first, then the b/w.
