View Full Version : Toner Not Turning in Konica Minolta di 550
nizar642
09-06-2009, 08:47 PM
hello..
i have a problem in my copier " konica minolta di 550 " , the copies are not clear and pale, bcz the toner not turning automatically..
:confused:
Any One Help Please ?
Thanks All For Reading
mascan42
09-07-2009, 02:30 AM
Is the toner trying to turn and failing, or is it not even trying?
your Develop still good condition ? how the value of ADTC ratio ?
toner tank spong roller ok?
nizar642
09-07-2009, 04:49 PM
mascan42 reply : Thanks For Replies, The Toner Is now not even turning, but only one time it turned after i touched it with my hand. but right now it's not even turning, and the toner is light not heavy..-------------------------------------------------------------ck1 reply : The Devloper is in nice condition, i cleaned it and i filled it manually with ink.but the devloper is not turning too.. to throw the ink to the printing box..and toner tank spong roller is still ok too.
PaperCut
09-08-2009, 01:11 AM
Clean the toner hopper, sensor, and check the gear too, On your developer check the gear if its turning.
copy40
09-08-2009, 03:07 PM
had a simalar problem on a di620, my fault that i hadn't fixed the rear panel on correct and there a sensor bottom left corner, (don't know what it does machine still copies but toner bottle will not turn) that needs to be blocked, have you had the back panel off or has it been moved??/??//?
sacha
09-12-2009, 12:03 AM
thank you all, my problem has be solved, the problem was that the developer ( poudre ) MT STARTED 502 .. was not enough ,
Hansoon
09-12-2009, 07:32 AM
:eek: :rolleyes:
Hans
