View Full Version : DF-605 paper jam on last original
blago_vd
09-08-2009, 07:19 AM
Hello everybody,
I have a problem with DF-605 mounted on Bh350. The machine indicates paper jam on DF when the last original passes through. There is no real jamming in the DF. The problem occures very often. I cleaned all sensors. Please if anybody has a solution help.
Thanks in advance
moonwalker3778
09-08-2009, 10:02 AM
check a small mylar sheet exact opposite to pre scanning sensor, it may be deformed.
Hello everybody,
Thanks in advance
torsion spring pn/4344505901 is broken and needs to be replaced. A little piece breaks off and causes jams. It is located in the back and takes 1-2hrs to replace.
Hansoon
09-08-2009, 07:57 PM
Or too much grease in the torque limiter spring. Clean part# 4344-5203-01 and 4344-5202-01 Hans
blago_vd
09-09-2009, 07:18 AM
But there is no jammed original, only indication, and always on the last sheet. After opening and closing the cover of the DF the jam indication is cleared.
moonwalker3778
09-09-2009, 08:36 AM
did u cross checked my suggestion?
