View Full Version : AR-c330 h5-01
agentholley
09-09-2009, 04:08 AM
Does anyone have any experience with this problem?
I would like the reset code.
Thanks much
OMD-227
09-09-2009, 05:02 AM
Have you cleared all the jams from the fuser & exit rollers?
Sim 14 will reset the trouble code and get you going.
If jams continue after warmup, double check jams in the fuser & exit rollers, as it's quite common.
danketch
09-09-2009, 05:32 AM
Thanks much
if you cannot reset the code in sim14, try the sim 16, and in the jamming use the silicon oil in the fixing assembly in the upper and lower hit roller
agentholley
09-09-2009, 12:06 PM
I can't get the reset codes to enter.
johnbla
09-09-2009, 09:35 PM
If you can't get the reset codes to enter...... Call a Qualified Sharp Engineer, who will also check and find the root cause of the problem.
