Question about changing developer on Bizhub 163
  • MihaiGSM
    • May 2025
    Hy guys! Today i changed the developer and drum on bizhub 163 because it showed on display "MaintenaceCall2". Everything fine, but after changing these, i did ATDC autoadjust with toner bottle inside, by mistake. The value of ATDC after the process finished was 143, i turned off and then on the copier, but the message "Maintenace call2" didn't disapear. To clear the message on the screen a did a reset on service menu.
    The copier work fine, the image on the paper is very good, but the question is: it will work again fine next 60.000 copies/prints? Thanks in advance!
  • harry2007
    • 52
    developer
    of course!...why not?the value 143 it's OK. it's no other reason for your concern.
    http://copierservicereset.com
    • perdana
      • Jan 2008
      • 62
      Maintenance Call 2
      You need to clear the Drum counter.
      • bechir00011
        • 24
        how can i clear thr drum and developer counters
        • mrwho
          Major Asshole!
          • 4299
          If it's the same as the 162, you need to clear the "Supplies Life Counter".
          Mascan42
          Ibid
