View Full Version : C6501 Skew
resolute
09-14-2009, 03:30 AM
I have a 1mm skew on the prints that I can't seem to correct. The skew is consistant.. it is always 1mm... I have found every other adjustment but cannot find a skew adjustment. I have cut my paper to 330mm x 487mm so that it is dead straight. Its really annoying on duplex jobs.. as the 1mm on each side = 2 mm on duplex. Because the machine is very very consistantly 1mm.. there has to be an adjustment for it... any assistance would be greatly appreciated.
Si@danwood
09-14-2009, 06:12 AM
Within spec.
Setright
09-17-2009, 12:10 PM
Yes, I have to concur. 1mm is within the specs/tolerance for the machine.
You might be able to reduce it 0.5, and effectively hit 1mm in duplex...if you are patient :-)
First off, the LCT paper cassettes (4&5, if fitted) are best to use, since this assembly has a sensor to monitor the edge of the paper and make electronic corrections for skewed paper feeding.
Any cassette should have the guides fitting snugly on the paper stack, any slack down here will make further efforts superfluous. Again, the internal cassettes are less well suited to this, but you can usually glue a plastic stip onto the guides to ensure a tight fit against the paper.
Right....
On the display panel, you should have a button in the bottom of the copy menu, that reads "Adj. Both sides" or something similar. It's the second one from the right.
This allows you to move the print indepently in simplex and duplex, zoom to compensate for paper shrinkage, and increase the registration loop. The latter being where I would begin, try a value like +30. In essence this increases the time the printer uses to straighten up incoming paper. You will know when you increase it to much, because the paper will start to buckle and get crease marks.
If this useless, try printing the chart adjustment. It will output a page with lines for you to measure. Enter these measurements into the provided spaces and the printer will try to compensate for the paper's tendency to twist/shrink during the printing process.
Best of luck :-)
BVulgaris
03-21-2012, 08:24 PM
I have a similar issue where i am getting a skew within spec, however its annoying because the skew is for the most part consistently in the same direction (if it was 100% consistent, i can fix my other machines to compensate). The skew is across stocks ranging from 13x19STD (or non standard sized around there.... skew actually gets worse with standard sizes), to 12x18 and seems to straighten out around 11x17STD to 8.5x11STD.
There is also an issue with the way it prints... seems to have a warp to the image considering i will duplex on cardstock 13x19 with a 12x18 fine point rectangle front and back, i can get the centers to line up but cannot get the rectangles to match as a result of what I originally thought was the skew but after measuring the dimensions of the rectangle I find the rectangle is slightly warped as well.
This is printing from Tray 5 LCT btw. The default for this tray's preregistration is set as -60 (is this correct?).
So i guess my question is how can I tell if this is just a physical issue with the tray/machine setup, or whether something more worrying is occurring in the print engine?
(yes, i have followed the proper setup for the FD and CD mag as well as CD skew, etc. I get 280mm cross wise in both directions for CD-skew.)
Setright
03-22-2012, 10:34 AM
Skewing within spec, mostly to the same side....sounds frighteningly familiar to me!
We had a machine that we spent days and weeks on, but nothing could solve the skew. It is within spec, but I agree with, when it's always to one side, and consistently the same amount, you would think it could be corrected somehow.
Please don't waste your youth on this problem. Sounds like you have already been through all the correct adjustment methods.
There are two things you might want to check:
Squareness of the customer's paper. Slight trapezium shapes, where one end is wider than the other will confuse the edge sensors.
Level of the print engine and the paper cassettes. If the floor is soft, the machine will sink further than the cassette, and need re-adjustment after a week or two. If the cassette and engine aren't aligned, you will have trouble with skew and registration.
BEst of luck!!
BVulgaris
03-22-2012, 11:01 PM
i've been trying to learn as much as I can about this product because i'm not sure its actually setup right (A tech to production is like the christian messiah, if you cant trust to follow him there are bigger issues in heaven's kingdom (no i'm not religious it just seems like a good analogy)), that being said my policy is i'd rather know whats right than be right. I've had some situations where I wonder if following the suggested setups are overkill as has been suggested to me, however i'm sure there is a reason its in the servicing manuals etc if it mentions it. (ie, disposing of 2 the PFU leveling feet, only having 2 diagonally from each other supporting the PFU as was suggested to me). Thus i'm trying to learn as much as I can both for myself and so the tech and I can communicate effectively if an issue arises.
As far as I can tell the chasis of the engine and the PFU are level (using a 2ft construction level on the top of both units). However what do you mean by the paper cassette? (the tray hold where the paper rests?... sorry a little fuzzy on terminology some times). Im guessing if the chassis is not level and the trays try to hang plum to ground.... (on the right track?).
We do have carpet in production, but it is a tight weave hotel grade carpet with no extra padding added between the carpet and the cement (interesting renno job). I have read a comment about not placing these things on shag..... i could just imagine the problems that would cause.
As for the paper geometry, i have painstakingly tried to eliminate this by weekly assuring our cutter setup is straight and even cutting the paper to the print size when needed (stock left slightly larger in storage and then cut before loading the trays. I try to look for ways to eliminate human error, but its possible i'm over thinking some things. :) (btw, what is the sensor tolerance or accuracy? are we talking about a difference of .1mm or are we talking a fraction of that?)
Thank you ever so much for your time and effort in helping to solving this problem :)
TonerMonkey
03-23-2012, 12:46 AM
BEst of luck!!
Agree.
BVulgaris: Do you think your tech/s are not the most switched on of fellows ?
If a digital machine is skewing by 1mm and it's not satisfactory you really need to take the next step up - buy a litho press, HP Indigo, NexPress or iGen. You get what you pay for.
Come on fella, 1 mm ? .... our lives are hard enough, have some tolerance.
It may not be achievable, and as I'm sure you may have picked up it's within spec for this machine. The members of this forum would I'm sure help you the best they could if it was possible to get a better result and there's a whole wealth and many years of experience here.
Good luck on reaching Nirvana, I've never been there ........... :o
Setright
03-23-2012, 07:04 AM
TonerMonkey..you forgot one machine: Canon imagePRESS :)
Setright
03-23-2012, 07:06 AM
Oh yeah, with respect to leveling/aligning, it's the metal frame of the engine and PFU that must line up vertically. The spirit level across the top is good as a guide, but ultimately, the plastic covers cannot be trusted to be perfectly straight.
BVulgaris
03-23-2012, 09:02 PM
Toner Monkey,
I completely agree that what I would like to see is probably pushing it which is why I am trying different venues and see what others have done to come up with a solution. Having 2 machines printing side by side with one printing perfectly out of the bypass putting the PFU registration to shame is strange considering the design.
I do not fault my tech for the work he does. I fault myself if i want to lower the tolerance and gett a better result. There are things that i've begun to question but again I am not a tech so who am I to judge? I do however wish to continue learning as much as possible, mainly because i find these machines fascinating.
I am however puzzled why numerous posters comment that trying to get better registration with the bypass without a PFU attachment is insane when the bypass proves more reliable in this respect (i feel i can only be led to believe that something is not right but i'm open to the possibility that i am wrong).
I have acquired a copy of a service manual/parts manual, and user manual in the attempt to reach "nirvana" with this machine but I do not expect heaven to appear in it's output. Any help that can be offered would be greatly appreciated however :)
Setright,
Thank you for the suggestion, i'll see if the metal framing is level etc.
To all,
To make it perfectly clear, i am not sitting on my tech whipping him to get the in tolerance skew fixed... I am simply wishing to raise my hand and ask what Me, Myself, and I can do about it if my employer has chosen this machine as making the most sense for our operation and pocket book as far as the digital side of things :)
Again, thank you all for your time and help.
I have youth to waste on something... im just not choosing sex, drugs and rock and roll just yet. ;) (though i miss the good music of the 80's .... i mean just compare HART-Alone to the remake Alone Again..... sorry side rant)
BVulgaris
03-23-2012, 11:44 PM
So I took a look at a PDF from another post that Stirton.M (sorry if i get spelling wrong) posted, which mentions the PFU guide rail should be within 3mm of the PFU frame (I find 2mm in the Service manual). Currently I have a measurement of 8mm. How critical is this distance?
In the setup it suggests that if this distance is >3mm then you have to raise the "right front adjuster of the PFU".
Our tech has told us that the PFU only needs the 2 support feet diagonally situated (or "its fine"). the third one is half way between the floor and the chassis and the fourth one I rescued from the trash where the tech threw it. (had an idea to use it for another project at home if it truly wasn't needed.
I currently cannot adjust the "right front adjuster of the PFU" mainly because it was never attached.
These are the things confusing me. I can deal with what I have... i can accept if i'm being a bit too demanding... its just a nagging feeling :)
dljorg
03-05-2013, 10:00 PM
The thing is in spec - so live with it.
Given that the skew is consistent I would conclude that the paper path is OK.
There are skew adjustments in service mode Machine section that allow measuring crosswise on test pattern 16. Adjustment changes the Image Processing Board writing method. Parameter is CD Skew.
Also there is a way to beat skew in the front to back registration section of the paper settings. You print a test pattern, measure some lines and enter the numbers in the system and it corrects for the errors you measure. Have to do that for all the paper types in the library though.
BVulgaris
03-05-2013, 10:15 PM
Allready done that... thx for the attitude.
In spec..... i keep hearing this but every time i look at the published specs for a KM 6501, it is not in spec. Again, thx for playing :)
This issue has been solved in a much different manner so im not worried about it but incase you were wondering, the last time i checked the machine i got 1-2mm sheet to sheet and 3-4mm FTB, and according to the manufacturer published specs, this is out of spec ;)
I dont complain about hot coffee.
eifling
03-06-2013, 01:16 PM
I think he was talking about taking a step up ;)
Setright
03-06-2013, 01:49 PM
8mm ?! Sounds a bit large, but it's hard to be sure we are talking about the same measurement.
Look here: The paper cassette, the part that moves out of the frame, at the top left you will notice a 5mm metal shaft/axle that sticks out when the rollers are up. As you close the cassette, the rollers pushed down and that metal shaft tucks in to avoid colliding with the frame.
With the cassette moved in, and the shaft retracted, I usually set the gap between the frame and the end of the axle to 2-3mm.
Keep trying :-)
Texers
03-06-2013, 02:47 PM
i havent read all the thread so if this has been pointed out before.. i appologise.
if the skew comes from PFU then perhaps it is needed to be leveled properly.
if skew is on the m/c then there are 2 skew adjustments 1 on the ADU on the registration roller and the other one on the paper exit assy.
for that one on the registration you need to loosen 2 screws at the back + 1 screw on the on top. then the whole registration assy can move front and back and can correct your skew.
the other one on the paper exit, you will need to remove 1 screw and loose the other 2..and then you can adjust.
also if you have fiery you could use tray alignement.. sometimes works wonders..
hope this helps
dljorg
03-25-2013, 09:18 PM
Definitely in spec.
Tried the CD skew adjustment? Its in both service and in Machine Manager / Expert
BVulgaris
03-26-2013, 12:56 AM
Definitely in spec.
urm... just wondering,
What is in spec?
What is the spec?
What machine are you talking about?
Do you have a published article, manual etc with this specification listed?
Just trying to find out more, its always possible i've missed something! (thank you!)
Setright
03-26-2013, 01:07 PM
Attached is a page from the confidential tech specs.
0.5% is a large deflection, and it seems to prove that you are operating within the specs as mentioned.
That does not mean that you cannot achieve better, but it does mean two very important things:
1) No technician can reasonably be expected to make the prints skew less.
2) Those who do decide to work for improvement have to keep in mind that the margin of error is larger than the target.
Good luck :)
