View Full Version : service code for konica 7085
Dennis Ellingson
09-14-2009, 07:24 PM
I need to know what the service code of a konica 7085 the code is SC36-05.
dawood
09-14-2009, 08:38 PM
Hi, Please follow the below instruction
SC (F) 36-05 - Fixing sensor abnormality - TH2 (fixing temperature 2) abnormality detection (by hardware). Under heating (-6°C or less) or overheating (240.5°C or more) was detected for TH2 output voltage by the comparator circuit.
I would suggest Please clean the fixing unit completely in the sensors area full and go to 2-5 mode on in the MFP and follow the below details.
WARNING
• When F34-.., F35-.. or
F36-..(fixing temperature
related abnormality)
occurs, be sure to repair
a efective part before
setting the 25 DIPSW 3-1
to 0. If the 25 DIPSW 3-1
is set to 0 without
repairing a defective part,
this may cause a fire.
if the service call problem still comes then you will need to check one of the below parts.
PRCB (printer control board)
ACDB (AC drive board)
L2 (fixing heater lamp 1)
L3 (fixing heater lamp 2)
L4 (fixing heater lamp 3)
TH1 (fixing temperature 1)
TH3 (fixing temperature 3)
TH4 (fixing temperature 4)
Thanks and Regards,
Dawood
Dennis Ellingson
09-14-2009, 09:11 PM
I want to thank you for the quick response! It has helped me out immensely. :):):):) Copier will be up and running shortly!
