View Full Version : C250/C252 Transfer Belt reset help
OBXtech
09-15-2009, 09:20 PM
This is a problem that has plagued our service department for a while. I am new to the site and thought I would see if anyone out there can assist me. We have reset transfer belts on other color Bizhub models (C350, C450, etc) by simply replacing the fuse, but that does not seem to work on the C250 & C252 models. The "replace" message is still there after we replace the fuse. :confused: Has anyone else had this problem? Is there something that cams upon installation that lets the machine know that there is a new unit? Any insight would be greatly appreciated. Thanks.
EarthKmTech
09-15-2009, 10:34 PM
Absolutely nothing special about the procedure, we use the same fuses as per the c450, 350 etc. Never ever had a single problem.
just ensure you are using the correct rating fuse, that’s going to be your problem, haven’t got one on hand at the moment to check its value.
copytechman
09-16-2009, 02:41 AM
Same as prior poster, we use the same fuse for the 8031/c350/c450/c250/c252/c352 and the c451 and c203 series.... a 1/16 amp glass fuse... worked every time unless I used the wrong rating fuse by accident!
Regards!
A!
OBXtech
09-16-2009, 02:25 PM
OK...so I cracked open 2 transfer belts. One is for a C250/C252 and the other is for a C203/C253. The C250 transfer belt has a 200mA fuse and the C203 belt has an 80mA fuse. Interchangable? I wouldn't think so, but maybe I'm crazy. Will the 80mA work in place of a 200mA? From what the last 2 posts state, then my answer is "yes." In my mind this doesn't work, but then again, my mind has let me down before...:D
emujo
09-16-2009, 02:52 PM
Fuses are available at http://www.digikey.com/ (http://www.digikey.com/)
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND is the fuse to blow the transfer belts up to C650
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Hope this helps Emujo
joeyl328
09-23-2009, 10:10 PM
So how do you replace the fuse? I have read a few posts about how this will reset the "replace transfer unit" warning, but no one has really said how to get to it. Where is the fuse? Thanks
EarthKmTech
09-23-2009, 10:20 PM
as you stand at the front of the machine and slide the transfer belt out, its hidden in the front corner of the transfer belt assembly. you need to loosen the top plate with the separator, remove the side plate with 1 screw and one E clip and a spring. you then have access to the little black cover with 2 contacts, you need a precision philips screw driver to open it. the fuse is in that black cover.
joeyl328
09-24-2009, 01:30 AM
Where can I find a 80ma fuse? I checked 3 hardware stores and radio shack, the lowest rating I can find is .315 amp. Will that work?:confused::confused::confused:
pepper38_cnd
09-24-2009, 11:28 AM
joey I would not chance using a 315 MA fuse. The OEM Fuse in Canada is a 1/16 A or 62MA we use 63MA fuses because they are readily available, I have been told you can use anything from 50MA to 200MA I personally would try to stay as close to the OEM as possible.
copytechman
09-24-2009, 01:19 PM
You can get them from digikey... thats where mine come from (both types, the pico and the glass ones.)
Regards!
A.
joeyl328
09-24-2009, 05:25 PM
so one final question: a friend of mine brought over 200ma fuses, will that work, or is that still too high? I've seen some posts saying it is ok, but I just want to make sure...
clueless
12-14-2009, 07:40 PM
When you refer to "the front of the machine", do you mean where the toner is loaded or the side that drops down to locate the rollers and release paper jam?
clueless
12-14-2009, 08:31 PM
Please tell me where to find the transfer unit. When you say "the front of the machine", do you mean where the toner is loaded or do you mean the side where the rollers are to clear paper jams?:(:confused:
I would not go whit 0.200 mA fuzes! I tried 0.100 mA on c352 and it is working but i don't recommend (i was bit in hurry :o and didn't have 0.80). Try to find or 0.80 mA (or 0.080A) or lower to be a safe. On c353 series, don't go anything above 0.80mA!
Yes, the right hand side. Pull down the transport section and there are 2 screws that hold the transport belt locking plates. Remove the screws and pull the plates out a bit. Now you can remove the transfer belt unit.
Having a ball
12-16-2009, 12:30 PM
this could be the HV contact that blows the fuse check the contact.
Dave10
05-05-2010, 08:50 PM
You want the fuse to blow. The 80 ma fuse is fine to use in place of the 200ma, because the lower rating is fine when you want the fuse to blow. However, the small current passing thru the fuse may not be enough to blow a 200ma fuse, and you have a problem. If you don't want to blow the fuse, then the opposite is true. We use the 80 ma or even 63 ma for everything.
pobenreder
12-17-2010, 02:29 AM
Make sure you use an 80ma fuse,no larger. Just did one yesterday
RockETop
12-18-2010, 04:50 PM
Yes, the .315 amp fuse has worked.
Stirton.M
12-18-2010, 10:48 PM
Just a note...pay attention to the post date
This one is ancient...its a safe bet that the solution has been found.
Look for posts that are a week old or less. No point in bringing old posts like this to the surface.
ptrflrs
12-19-2010, 04:09 AM
finding the 80ma fuses is the hard part but they are online, google is your friend.
Printer People
04-08-2015, 12:53 PM
See the pictures for were the fuse is:
