View Full Version : Minolta CF3102 Image Printing Problem
Savannah67
09-27-2009, 08:32 AM
I was wondering if someone could help me diagnose what is wrong with my copier that it would be printing images like this:
http://i264.photobucket.com/albums/ii187/chelstin09/IMGP8769.jpg
I bought this copier from a friend a few years ago and know NOTHING. Any help is greatly appreciated!!! :) Thanks, Chelsea
minimerlin
09-27-2009, 11:05 AM
I think it needs a doctor...too many pills!!
No seriously , the Magenta Image unit looks faulty or low on toner, can you print just test color sheets of each color and that should show the faulty area.
Savannah67
09-27-2009, 05:23 PM
haha :D. I have printed test sheets previously, but for the life of me I can not figure out how to do it again...?
Si@danwood
09-27-2009, 05:39 PM
Yep definatly a failed magenta iu possibly a dodgy cyan as well..Si
Savannah67
09-27-2009, 05:41 PM
When I print solid Cyan & Magneta colors they print "thick" & fuzzy, could the imagining units be the reason for it?
Si@danwood
09-27-2009, 05:44 PM
Is the machine level?
Savannah67
09-27-2009, 05:45 PM
I believe so.
Si@danwood
09-27-2009, 05:47 PM
ok if full on colours seem ok then it may dirt on the print heads!Other than than i would go with Imaging units! What do the prints look like when you print gradation patterns for each colour?
Savannah67
09-27-2009, 05:48 PM
Actually one of the wheels broke off.... could that be causing it?
Si@danwood
09-27-2009, 05:49 PM
Broke from where?
Savannah67
09-27-2009, 05:52 PM
I think the corner of the main machine (not the scanner). It happened when we moved, somehow it cut in half and fell off
Savannah67
09-27-2009, 05:54 PM
The back right hand wheel is the one missing
mascan42
09-28-2009, 02:21 AM
If the printer part isn't sitting level, the developer in the image units might not be evenly distributed. Are you having a similar problem with the black ink as well? That's the one closest to the broken wheel, so it would probably be the one most affected if that's the issue.
mascan42
09-28-2009, 02:42 AM
Also, the base of the printer can be bolted to the scanner stand with the proper hardware. That would keep the printer from going off-balance in the future.
Savannah67
09-28-2009, 03:12 AM
I will have to take a look at that. Honestly the only colors I have problems with are Magenta and Cyan. Black prints perfectly.
