View Full Version : di450 toner fly on t & s charger
Matoku
10-05-2009, 06:46 AM
this di450 dv and drum already changed. the transfer block always soiled with thin of toner.cause the back side of paper get dirty.after I clean the paper guide (with plastic insulator) only 1 copies then it dirty again.
anyone know how to solve this problem.
did you check the anti spill plate ??? :confused:
wcastelli
10-05-2009, 05:27 PM
Try cleaning the bias contacts on the back of the developer unit and the rear frame of the copier, then regrease with conductive grease.
Darren King
10-05-2009, 09:47 PM
Lower the metal guide on the trans/sep corona
Hope this helps
Darren
Matoku
10-06-2009, 01:54 AM
:cool:thanks for your reply,
the final solution is the t & S block I change.
alexg
10-06-2009, 11:08 AM
This model uses to have problems with separation between drum and developer roller, there are two rollers in both sides of the magnetic roller. Try to replace them. These rollers have to be new with each drum replaced.
Good luck.
