View Full Version : Bizhub ColorForce 8050
copyfax20
10-09-2009, 04:10 PM
A touchscreen display panel control not respond when touch. When i send print's the copier waited between pages more time.
random
10-10-2009, 09:19 PM
This can sometimes happen when something gets stuck between the touch screen and the edge surrounding it. Get a business card or something and squeeze it between edge of the touchscreen and the plastic surround. move along all four edges to remove the debris.
RRodgers
10-11-2009, 07:52 PM
completely shut the copier down (the switch inside the front door. Fire it back up and see if it works fine for a while. If it does, you need to patch the Fiery. I'm pretty sure you have a 921 on it.
shawn Xia
10-12-2009, 08:25 AM
does it work well at copy mode?
copyfax20
10-12-2009, 01:11 PM
Yes, in copy mode work ok, but sometimes touchscreen not respond.
Waiting failure only as presented when i send print's
copyfax20
10-12-2009, 01:13 PM
I already removed and clean the panel but still does not work, takes some calibration or adjustment mode?
RRodgers
10-21-2009, 01:04 PM
Did you patch the Fiery? Is the Fiery an internal one? This IS a known issue.
