View Full Version : Bizhub pro c6500 error c2424
xcopy
10-12-2009, 04:21 AM
Just changed k dev and this error has come up, any ideas?
Check the TCR K sensor, may be it has detected the lower value. Also check the Dev Motor.
Regards,
shawn Xia
10-12-2009, 07:54 AM
(1)PRCB BOARD
(2)DEV MOTOR K
(3)TCR SENSOR K
maybe the dev motor k can't start or TCR SENSOR K DAMAGE
Avalon
10-12-2009, 08:13 PM
I have this vague idea that this can happen if the machine runs out toner whilst doing the dev initialisation and setup.Worth a try ?
lucky13
10-12-2009, 11:58 PM
had that code this morning check the 4 pin connector on the front of dev unit my blue wire got pulled out gust a hair from the back side of connector also check for a bent pin
Cleaningblade
10-24-2009, 10:14 AM
i had 2421 yellow dev
replaced the yellow unit, after a week ihad the same problem
The problem was the cable clamp/cabelretainer ?
I dont knowexactly how to translate Kabelbinder ;-)
