View Full Version : Bizhub 6501 fiery problem
thuo
10-13-2009, 02:52 PM
have a bizhub c 6501 fitted with a fiery.once the machine finishes printing one job the controller tab(option on the display becomes inactive) goes off untill the machine is restarted.
any idea
thanks
thuo
10-13-2009, 04:03 PM
any idea
thanks
urgent
Albonline
10-13-2009, 04:40 PM
which firey? if 408 ds 2-1 must be set to on
Setright
10-15-2009, 01:01 PM
I would start as stated above. Otherwise:
Switch off the controller and the printer on the mains.
Remove and re-install the SCSI cable between them. Sometimes the connection isn't mechanically sound.
The interface boards can also be out of sync, and require replacing, but this usually gives more random faults, yours is repeatable.
thuo
10-15-2009, 02:25 PM
have connected the faulty fiery to another machine behaves the same.memory or hard disk suspect.any reset cure for this problem
RRodgers
10-15-2009, 07:31 PM
Have you looked to see if there is a firmware update for this? Or a patch for the fiery?
random
10-16-2009, 06:01 AM
what options are on the machine
