Bizhub 750:Please wait
  • Copper
    • Jun 2025
    A new m/c +/- 13k copies,started with please wait warming up.Cleaned TDS sensors,no joy replaced TSD,drum,developer and dev tanks, nada. Have replaced system PCB & Optics PCB,still nothing.will check door switches in the am and power supplies.This one is gonna make me gaga,will really apreciate any suggestions!
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    Try the LVPS. Can you get far enough to get any codes?
    • Downunder
      • Aug 2007
      • 174
      Could be the flash cards. Either try updating firmware through the back-door (turn copier off, turn back on while holding utility key down, press trouble reset, then go straight into tech mode.) Also can try leaving the copier off over night and let all the capacitors discharge and then try in the morning. Don't laugh - has worked on a few occasions.
      • Lanimal
        Bizhub 750 Please Wait
        Look in the Errorcodelist, (Tech Rep Mode) There may be some dirt on the Gamma Sensor. Good Luck
        • chand226
          • 38
          Re: Bizhub 750:Please wait
          no need of to change any firmware and drum.
          i have 200% correct formula for this copier (biz600/750/ di7210/7272). no toner on corona, no warming up, pleasewait.
          contact me at chand226@gmail.com
          • chand226
            • 38
