View Full Version : bizhub 350, turn off scan confirmation page
fixthecopier
10-16-2009, 11:10 AM
After I installed the fax kit in this and set it to print a confirmation page for every fax sent, she called back and said that it was printing one for every page scanned also. Is there a soft switch setting to separate the two?
mascan42
10-16-2009, 01:19 PM
Turn soft switch 368 bit 1 to 0.
fixthecopier
10-16-2009, 09:45 PM
Thanks for the reply but the new bizhubs are a little different. When you go to soft switch settings, you enter a 3 digit number for MODE, then it will pull up an 8 digit string with the "1's and 0's" you flip those to make changes. I will have to find the mode and then which bit to change.
mascan42
10-16-2009, 10:24 PM
Mode 368, bit 1. Switch it to 0.
It should read 11000000 when you're done.
fixthecopier
10-17-2009, 12:05 AM
Sorry for the confusion. I thought maybe you saying mode but when I used that I must of looked at the string backwards or something and I just wanted to clarify. Thanks again for your input.
