Bizhub 200 User Box problem
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    I've got a Bizhub 200 w/ HDD (I have successfully installed and formatted the HDD). I'm trying to set up the User Box function, but keep hitting a snag. I have gone into WebConnection and set up the Box and it does show up on the one-touch menu on the control panel of the machine. I can even scan to it and retrieve the file from WebConnection.
    But that's the ONLY way I can get it to work.
    I'm trying to access the User Box via the control panel - there should be an option on the main COPY screen (bottom left-hand corner) that says "Save to User Box." That option is not there. How do I get that option to show up? Any ideas????
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Update your firmware to phase 2.5, as I think your firmware might be why you cannot see the button. It should be available on your copy screen directly.
    Failing that, you can simply create a one touch through the utility key.
    Konica Minolta Knowlegebase
    to download the manual for that program.
    Box Operations
    Click the blue disk shaped icon with the red arrow to download.
    Last edited by Stirton.M; 10-23-2009, 02:24 AM. Reason: something wrong with file attachments
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
