View Full Version : Auto Document Feeder BizHub210
ravikumarj
10-25-2009, 06:31 AM
Every single original feeds in primary then get jammed.
Any sensor or the board in ADF.
I ve removed, cleaned the feed rollers and sensor.
Kindly help me with solution.
Thanks in advance.
Ravi.
moonwalker3778
10-26-2009, 08:22 AM
there is a pre scanning sensor,just before the original turns in to platen glass,opposite to that sensor one Mylar sheet is there that may be worn out or deformed. hope this helps you
ravikumarj
10-26-2009, 09:21 AM
Thanks for the post, I found there is no obstruction of mylar, I ve already fed thick sheet and cleared the path.
It takes the primary feed then it stops in the glass.
Any sensor can be suspected?
Ravi.
The hook of feeder lock lever might be broken on the rear side.
