View Full Version : Bizhub 600 web interface won't load
paulterack
10-26-2009, 04:57 AM
I'm having a heck of a time here. I cannot get my web interface to load up.
Here's what I've tried:
XP Pro machine
Tried both Firefox and IE 8
Tried both https://10.10.1.12 and no httpS
I CAN ping the machine no problem
I can print to it not problem
I can scan to SMB when I manually enter server settings
But, I cannot load the web interface to setup, among other things, SMB destinations.
buster68
10-26-2009, 01:30 PM
If a Microsoft Auto update has taken place on the XP computer, more than likely if now has Framework.net 3.0. Without a firmware update on the bizhub600, Framework will block the machines web interface. Or if the copier is up to date, the Pagescope Web Connection (PSWC) has been turned off in the Network Settings of the copier. Look for the Details icon in the network setting, you should see PSWC or HTTP settings.
paulterack
10-26-2009, 04:55 PM
Ok, I went into details and both the HTTP and PSWC were disabled. I enabled them, but now I'm getting a different error, namely:
"503 Service Unavailable"
I can check the firmware and tell you what versions I have. What specific function should I check for firmware because there are like 10 different firmwares on there.
thanks.
emujo
10-26-2009, 10:23 PM
Seen that error trying to open Page Scope with IE 8. Try Mozilla again or a lower version of IE. EMujo
paulterack
10-26-2009, 10:26 PM
I tried IE 8 and Firefox....same error.
paulterack
10-26-2009, 11:03 PM
I got it working now...don't ask me what changed....I have no idea.
