Di850 EDH Dead
  • Dedotch
    • Oct 2008
    • 40
    Di850 EDH Dead
    MY EDH has died. Nothing really happened. The feed roller slipped out of the bearing and caused it not to feed. Fixed that now it is dead, no errors or communication to the machine. Thanks in advance for your help. Scott
  • Dedotch
    • Oct 2008
    • 40
    Di850 EDH
    Is there a reset. Or a fuse. I checked the 5v to the EDH board it is present. Don't know where to go next.
    • Dedotch
      • Oct 2008
      • 40
      Software Switch
      I think all I have to do is turn it back on. It may have been iso faulted to off. Can someone please give me the switch # for the EDH of a Minolta Di850. Thanks
      • tony_218
        • Oct 2007
        • 24
        di 850
        el swit 18 en el mode 25 pero el mio no se puede habilitar por este sistema se ha bloqueado
        • albasoul06
          EDH-5, not recognized by main body.
          Solution
          CAUSE: The EDH is not selected in the 25 mode.
          SOLUTION: To select the RADF in the 25 mode, perform the following:
          1. Access the 25 mode (power the machine OFF while holding down on the 2 and 5 keys).
          2. Select [1 Software DIP SW].
          3. Select DIP SW 18 using the up/down button at the left.
          4. Select bit 4 using the up/down on the right.
          5. Select OFF
          6. Press the PREVIOUS SCREEN button to return to the 25 mode.
          7. Power the machine OFF/ON to exit the 25 mode.
          The 47 mode can be used to check the sensors and motors. Code 060 has several tests for the document feeder.
          Let me know if you need EDH-2 Book
          • quickdraw44
            EDH book 2
            Yes I would like to receive one.
