Bizhub C650 banding
  • renot
    • 6
    Bizhub C650 banding
    Yellow imaging units are only lasting for about 3 weeks and banding starts to occur. The problem looks just like the C450's that would leak developer and required new shutters and seals on the toner hopper. I did replace the shutters and seals on the C650 but the problem has returned. Has anyone else experienced this problem?
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    We are seeing this ourselves from time to time. There really is no rhyme or reason with respect to any one machine. It appears the problem is batch related, and yellow seems almost ALWAYS the one to go.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • buster68
      • Nov 2008
      • 181
      you don't have enough pressure from the lock levers for the imaging units.
      You need to increase the thickness of the black spongepad on the blue lock levers. I've found that if I cut up the thick mylar cover that comes with the BH350 for the scanner lock into 1cm squares, and put about 3-4 stacked on the black pad, it creates enough pressure so the iu's don't lose bias.
      • Stirton.M
        • Oct 2009
        • 1804
        Good tip....I suspected it might be something like that, though usually I see this with the back IU lever is not locked. I'll have to try this.
        ---Groucho Marx
