View Full Version : 6501vs 6500 charger
levino
11-02-2009, 06:25 PM
Hai,
Any difference between KM 6500 and 6501 charger units?
Thanks!!!!
Si@danwood
11-02-2009, 06:45 PM
No both use A03ur70300. However the C500 coronas work , but are approx 4 x the price!! Si
tech51
11-02-2009, 07:00 PM
They are different. 6501 charge units are designed to use a height adjuster (to help eliminate uneven prints). I don`t know if they are compatable with each other, Ive never tried fitting a 6500 corona into a 6501 (or vice versa). If anyone has tried and results are ok please let me know so I can reduce my car stock !!!!
Part numbers are A0UR71200 = 6501, A03UR70300 = 6500. Cheers:)
Albonline
11-02-2009, 08:23 PM
6500 crg units in 6501 will bite you in the but! they only last a short while before causing cq and misting problems.
levino
11-03-2009, 05:03 PM
hai Tech51,
I also think these two are different,because the design of the body is different
Thanx
Si@danwood
11-03-2009, 06:48 PM
News to me we have been using the same(A03ur70300) with no ill effects whatsover for the last 9 months..... We cant have been that lucky surely!!:confused: Si
brian155
11-06-2009, 10:15 AM
I agree with Si that A03ur70300 work with both but if you have a fussy customer try using the A03ur70300 housing with C500 gold coated grids for best results on copy quality.
StormyKnight
11-10-2009, 12:34 AM
Thats one thing I have noticed, these coronas can have either gold or silver grids....whats the go with that?
PS I haven't seen any issues with either though...
Si@danwood
11-10-2009, 06:08 AM
The gold coloured grids intially were for the c500,the silver for the c5500/6500. Both are interchangable but the gold ones giving a prolonged life.However the gold units are approx 4 x the cost of the silver ones! This would be ok if they lasted 4 x longer which inevitably they do not!! So its a personal judgement/call which ones to use..Si
StormyKnight
11-22-2009, 10:22 PM
Hmmm, perhaps the reason is that we have some coronas left over from the 8050 & they are gold.....
They still seem to work OK.
