View Full Version : konica minolta bizhub 210 c14a3 error
javier4065
11-04-2009, 04:45 AM
Hello friends This copier doesn,t work , display says C14a3 ERROR What Should I do to solve it? THANKS.
JustManuals
11-04-2009, 05:38 AM
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
from The Internet's largest collection of manuals (http://www.justmanuals.com)
Paul@justmanuals.com
jimmyj
11-04-2009, 02:18 PM
Make sure the CCD, Exposure Lamp, Inverter Board and Control Board are all working correctly. Then check the horizontal and vertical alignment of the CCD(Three adjusting screws located on the lens assembly)-Place the machine under a light source.Put a piece of paper against the CCD to check where the beam of light falls. It should fall in the middle of the sensor. Use the adjusting screws to make the adjustment. Don't loosen the screws marked in green.
montana
11-16-2009, 10:28 AM
hi...scaning lamp faulty......
javier4065
11-25-2009, 02:38 AM
thanks friends I cleaned the white mark under the glass .It was all.
