Here is the back round. This machine has 35K on the meter and on the
internal counters. The condition of the drums, chargers, dev, and
transfer belt look like they have closer to 100K. The copy also looked
that way. Not good.
This machine is one of three in the shop. I need to get it ready for next
week, it has been sold. The other two units have much higher meters
700K and 900K. The counters on these parts read about 6-8K and the
parts look like that is all is on them. So I put them in the unit with the
low meter, all at once. All from the same machine. I was doing the
adjustments when the code appeared. First I ran Initial drum rotation,
then auto color registration. That's when the code popped up.
I tried putting the old drum and charger back, but that was no help.
I also put another drum from the other unit in, no help.
I noticed that the drums were coated with toner on the transfer side.
I did clean the machine with compressed air. Just lite puffs from about
12-18 inches away, then wipe.
If I let this unit power up to copy it also gives the code.
The machine with the old looking parts stills fires up and make a copy.
A bad copy but no codes.
I'm still green on this model and could use some pointers.
DR
