View Full Version : cf9001 Problems again
BUSHWACKER
11-10-2009, 11:49 AM
Greetings all the cf9001 driving me dilly
Fan faulty as was correctly diagnosed by you kind folk.
I have however just powered the monster up th check a different fan
screen comes up with a message:
engine downloading completed
check sum
I.R.
N.G.:mad: HELP BEFORE I GO NUTS
THANX
BUSHWACKER
BUSHWACKER
11-12-2009, 09:58 AM
check sum
I.R.
THANX
BUSHWACKER
Well well I never thought I would see the day that I stumped the team.
No one in this neck of the woods is able to help either.:confused:
mrwho
11-12-2009, 10:23 AM
Did you by any chance forget to remove the firmware card from the machine's board?
BUSHWACKER
11-12-2009, 10:26 AM
No did not do anything related to firmware card, the machine was switched on and this message comes up on top of the normal info that is being displayed i.e error re fiery 24 volt fan which is unobtainable in South Africa
Regards
Bushwacker
mrwho
11-12-2009, 10:29 AM
So that error is related to the machine or to the Fiery?
Usually that kind of message pops up when finishing a firmware update on the machine. If it's Fiery related, then I can't see a connection.
BUSHWACKER
11-12-2009, 10:55 AM
No firmware update has been done, no card in the machine
The firmware update type message is appearing, but for no apparent reason.
The fiery problem re the fan is a seperate issue.
Regards
Brian ( Bushwacker)
mrwho
11-12-2009, 11:16 AM
Well, if that is so my guess is you have some kind of board problem.
If you can, try to reflash the machine's firmware. Also, check the boards for any bent pins and reseat all the connectors.
I can't think of anything else, sorry. Searched my docs and couldn't find anything like that.
kalindd
11-12-2009, 02:25 PM
I've seen this in the past.
As far as I remember the problem was fixed with reseating one of the eprom's on the machine pwb. the one top of the fiery.
Or you need to flash the firmware.
I hope this helps.
Stirton.M
11-12-2009, 03:43 PM
I went through what I had as well and found nothing.
This could have some to do with what I predicted earlier regarding this particular machine and the removal of the Fiery controller because of the bad fan. I suspected it would interfere with the inner workings of the machine if removed, but I wasn't sure because quite frankly, I've never worked on one without the fiery installed. There could be a correlation between the two.
Luong Nam
05-08-2010, 12:34 PM
Konica Minolta CF9001 SM
Go: Exchange Service Manual (http://multifunctionmachine.blogspot.com/)
Get free link at here
cyber61
08-23-2011, 06:52 PM
I have the same problem.
check sum
I.R.
N.G.
did you solve it?
I got the problem after the power plug was unplugged for a while (2 days)
Fiery is working and I get a connection but the hardware does not work.
...please HEEEELP.
THX a lot
cyber61
08-23-2011, 06:54 PM
check sum
I.R.
N.G.
did you solve it?
...please HEEEELP.
THX a lot
kniezarastislav
09-09-2011, 03:49 PM
Hello friend,
do you have a service manual for cf9001 please? Would help very much. My printer does not start at all. THX.
JustManuals
09-09-2011, 07:06 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
cyber61
10-10-2011, 09:29 PM
Hello friend,
Sorry - no Service manual - but I have got a solution for this problem. You have to download the patch 50371.uxe, connect cf9001 with parallel port, start your engine, press "set", select "install software", at DOS prompt copy 50371.uxe to lpt1 ...and it is fixed. Short description what I am trying to do since 2 month....:( - but it doesn´t work ---I GET NUTS!!!!!
Hope you are more successfull - if you are - let me know.
What problem do you have? Maybe I know it.
kniezarastislav
10-14-2011, 09:38 AM
Well, my printer was off for few years!!! so when I first started it, the power supply fired down, I repaired it, but today, when I started it again, the colour display does not start, but it seems to run - the fiery is on as it displayes on the small display. But the code 08C-M is displayed with the message of checking cable and power.
Does anybody have a suggest what to do?
When I want to print a test page, it displayes RIP :( What does it mean???
THX.
