View Full Version : C6501 Duplex Jam on Heavy (but in spec) cardstock
resolute
11-10-2009, 07:06 PM
I Have a C6501 - a lot of jams on Autoduplex. The paper I am using is within spec -- and uncoated - only 216gsm actually.
I jams whenever I try to run more than 1 sheet. If I send 1 sheet - it doesnt jam.. if i send 2 or 3 -- it jams.
There are a lot of settings that I can adjust.. but not sure what I can adjust to reduce the chances of it jamming.
Si@danwood
11-10-2009, 07:59 PM
Check and make sure the paper size corresponds to what the tray setting/print driver says!! A bit obvious i know but had a similiar only last friday!! ..Si
random
11-11-2009, 06:20 AM
Jam codes?
Stirton.M
11-12-2009, 12:50 AM
Jam codes?
I agree.
Jam codes will reveal what is really going on.
Adriaan
11-19-2009, 06:32 PM
Give some jamcodes and then you'll get some advice.
For instance: paper feed sensor directly after fuser :confused:
