View Full Version : Docucolor 12
jhricko
02-24-2007, 05:34 AM
I am having an oil problem on the doc 12. Replaced the oil assy., the oil pump, and the fuser rollers. It seems the oil is getting to the donner roller but not transfering over to the fuser roller. I checked the two springs on the oil assy. Any suggestions.
Does any one have a picture of the oil assy installed maybe I put something in wrong. I have the manual but it is lacking.
Thank You
edwin rocha
08-03-2007, 01:14 PM
check the oil system assy (donor roll, pick up roll, blade, oil wick and pad)for aging. i have encounter that problem and found out that shafting of pick up roll is not position properly. check the end bearing of pick up roll. check also the nvm for oil pump time.
patelkapil
09-16-2007, 03:07 PM
check out for the tension of springs on both sides and also check out for condition of pickup roller
