Oystercopy
11-18-2009, 01:46 PM
Took on a new customer with a few issues in the box and had some questions. I did a machine history and there were a lot of jamming codes, mostly from the Tray 2 that they were using as the primary Letter size. I moved the paper up from Tray 2 to Tray 1 to help pinpoint the problem.
They've also got something more serious going on with the Toner Bottle rotation. The bottle cannot be pulled out when empty, because the rotation of the bottle doesn't stop at "HOME" position. You have to try to rotate the bottle by hand to get it to the spot where the divet is so that you can get the bottle out. What's also strange is that the bottle KEEPS TURNING, even after you've opened the door, which I find odd. I would think it would want to stop turning right then, so that nothing was moving when the customer opened the door, for safety reasons.
My thoughts were that, possibly these issues might be related to firmware, as the firmware looks old to me. Since I've only updated firmware on the color machines, I'm wondering if someone could shed some light.
Thanks in advance,
OC
Thanks in advance,
OC
