View Full Version : Help for remove fuser unit Bizhub c451
babajaga
11-18-2009, 02:20 PM
I need help(step by step) to remove fuser unit. My machine is Bizhub c451.
Thanks!!!!!!
mo0651
11-18-2009, 02:32 PM
Step #1: Step away from the copier.
Step#2: Call a qualified technician.
Because you evidently can't see the 2 screws holding it in place.:cool:
babajaga
11-18-2009, 02:37 PM
thanks.
babajaga
11-26-2009, 07:05 AM
I successfuly reset fuser unit with new 80 ma fuse and all image drum with new chip.(black, yellow, magenta and cyan). :)
Now I need help how to remove transfer belt unit. I have 80 ma glass fuse, but i can not take down transfer belt unit. Sorry for my bad english. :(
minimerlin
11-26-2009, 08:02 PM
You are getting into dangerous areas now, it is easy to damage both machine and transfer belt assembly if you are not careful. I would also not advise resetting the transfer belt as you will get copy quality issues. I think it is time to either 1. Get a manual. or 2. call a tech who is trained on the machine.
