View Full Version : C352 "S1" displaying triangle
Haroldbfix
11-18-2009, 11:28 PM
Clean all print heads, clean optics and Re ran Stabilization and Gradation. Replaced CCD per SSD recommendations same issue. All new IU's
All ideas are welcomed.
copytechman
11-19-2009, 12:10 AM
Additional info if needed:
S-1: CCD clamp/gain adjustment failure
Relevant electrical parts
Scanner assy CCD sensor unit
Image processing board (IPB)
1 Correct the harness connection between CCDB and IPB if faulty.
2 Check for possible extraneous light and correct as necessary.
3 Clean the lens, mirrors, CCD surface, and shading sheet if dirty
4 Correct reflective mirror of the scanner if faulty, or change scanner.
5 Change CCD sensor unit.
6 Change IPB.
Basically points to scanner section, not a lot to do with iu's or printheads.
Regards!
A.
graphshooter
11-19-2009, 11:58 AM
Hi, try to replace the lamp p/n:9351 3300 11
Haroldbfix
12-06-2009, 10:02 PM
I ended up replacing the Lamp and the IPB. Did a trouble reset and re ran all gradation. So far so good. Thanks for the help.
