Hey Tech Gods,
I pulled the afore said finisher out of a site because it stopped working midway through a copy job. No codes or anything. Just will not function. The finisher works fine at our offices and is running great. On site it doesn't show that their is a finisher even attached to the machine. This Finisher also has the Staple Unit attached to it.
Question:
We are thinking that it is the power/logic connector on the back of the copier itself. Konica tells us to check the fuses. Has anyone else ran into this if so any fixes I should attempt before getting a new wiring harness and re-running that bad boy.
--Darphicus
Question:
--Darphicus
