View Full Version : di550 error c133b
mkdi550
11-20-2009, 06:18 PM
I was disconnecting the finisher while the copier was powered on and I got an error code c133b. I turned the copier off, reconnected the finisher, turned it back on and still get this error message. Can anyone help me with clearing it?
albasoul06
11-20-2009, 06:24 PM
The copier displays error code C-133B.
CAUSE: This code is displayed when there is a communication problem between the copier and the finisher.
SOLUTION: Please check all connections and inspect the interface harness. The firmware of the copier has been updated to correct the false indication of C-133B codes.
mkdi550
11-20-2009, 07:18 PM
I've reconnected the finisher, checked the interface and everything looks fine, but I'm still getting the error code.
minimerlin
11-20-2009, 08:15 PM
Have you tried to reset by cycling the front door and/or trouble reset switch?
fixthecopier
11-20-2009, 09:22 PM
I think I did the same thing once. I believe you have smoked the board on the finisher.
