View Full Version : Bizhub C250 paper jam in BayPass
robizhub
11-25-2009, 06:39 AM
Bizhub C250 paper jam in bypass with normal paper (A4)
I cleaned all that I could clean but 1 or 2 or 3 sheet goes normal and then jamm in fuser and in bypass.
Thanks!
tonerspot
11-25-2009, 09:15 AM
when you get the jam the paper pass the fuser or not
barratec
11-25-2009, 09:19 AM
I presume the size setting of the bypass tray is right,so you can try to adjust the "printer regist loop adjust" . You can find it in the 'SERVICE MODE' then 'MACHINE' then 'PRINTER RESIST LOOP'.
robizhub
11-25-2009, 10:50 AM
Thanks for answer!
Not pass the fuser i have 2 paper jamed:
One in bypass
second in fuser
thanks!
robizhub
11-25-2009, 11:45 AM
AFTER 'SERVICE MODE' then 'MACHINE' then 'PRINTER RESIST LOOP'
THEN FINE TUNNING
MACHINE RUN MUCH BETTER BUT SOME JAMM OCCUR BEFORE FUSER
THANKS.
